I have seen some examples of this but unsure how they were achieved. I am hoping the CE community can suggest a solution for view shed generation that can be used to colour objects. Any help/links/guidance would be greatly appreciated.
Dave
Unless I'm mistaken you can't do this in a webscene except by cloning your layers and applying different colors to the objects. If you group them when you export to web scene you can then turn them on and off.
Yes, I would suggest the same approach as LR. Perhaps you could use the occlusion tests (i.e. inside, overlaps) to color your objects.
