Have attributes from 1 point that display on map. Can't select it.
Try and select it. Most likely it is a text element on the layout.
Software?
It looks like a ghost of an attribute table. Did you try a save and reboot, and reload?
Yes sir, I did.
That’s the first thing I thought.
ArcMap? ArcGIS PRO? version?
Is the dataframe/map view?
layout?
you are sure they aren't graphics?
What if you open a new dataframe/map view and copy the files to there, one at a time... checking as you go... does it still persist?
ArcMap 10.2.1
dataframe/map & Layout view
Will have to check on the copy part.
Thanks for the help!
Ok.. older software, but I haven't seen a ghost bug
Right-click on each layer and make sure labels are turned off for each layer.
Close any tables you may have open
Now
Go to the Insert menu, select Dataframe.
Go back to your first dataframe, right-click, then Activate.
Now copy (or drag) one file at a time, into the data frame, note if any are showing up.
And it doesn’t appear to be a ghost, it prints in all views…
Actually it just got fixed it… It has not been selectable, but I tried one more time and it let me delete it!
I realize that I was trying to select it in editor mode. However the Item was not in the the SDE I was editing!
Duh....
Thanks for suggestions!
Every suggestion is a learning experience!
The missing bits... SDE and edit mode ...
Yeah, I never put the 2 together… But working through everbody’s suggestions got me there!!
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
