Dear fellows,
I have some issues in the visualization in my mosaic dataset, at resolution scale some images are displaying in a lower resolution than the original images. Why could be the reason for this behavior??
Tks,
MB
If you use ArcMap, open the layer properties and select the display tab.
The default resample method for mosaic is bilinear. Change it to nearest and you will see pixels.
The default is different for simple rasters - that is why you see pixels for them.
Have fun
I tried that already but it didn't work, the blurry effect only happens in certain areas of the mosaic dataset
