@Marco: I don't have the username and password for customer care...
P.S. How do I find out which version of SDE is installed (workgroup, Enterprise... ) ?P.P.S. I am thinking just now and this came to me:
I did the ArcSDE Geodatabase upgrade using a direct connection to the old 10g Oracle server from my new test server, through ArcCAtalog v10. But, I did not uninstall the old ArcSDE on the old server before I did the upgrade! Could this be a problem?!
Also, on my question, is the CD they gave me Enterprise or Workgroup, they said : "That is the only SDE install CD we have, so it must be correct. " 🙂 🙂
Yes, the log had no errors or warnings and it said that it finished succesfully. Also I tried to connect using ArcCatalog 9.2 and it said that it cannot access the later ArcSDE from an older release of ArcCatalog (or something like that). And the old server SDE service cannot start, so I think that the upgrade went ok.
Marco, I looked at my install DVD and could not find the installation of SQL Server Express, only ArcSDE for SQL Server... Does this mean, that I have the Enterprise DVD?M.
Yes, I have asked them to check version they gave me with the licenses.They say it is ok...I have reinstalled the server, Installed everything from the start, and still cannot do a direct connect.Also, the license update will not pass no matter what I try. The errors are all the same...This is useless!M.
@Marco: I don't have the username and password for customer care...@Vince: Yes, it contains the line...
That was my reply.The file contains the line that starts with arcsdeserver, only it is not a new line, but it only continues the line end of the previous feature (eg. svrstandard,100,ecp....arcsdeserver,100,ecp....).
I have asked them to give me the credentials, but they refused saying it will lead me to them again...
What annoys me the most is that I cannot do a direct connect... Through sqlplus it works from several machines, but through arccatalog it does not...I tried one more machine, but it will not connect the damn thing.
sqlplus sde/password@instance UPDATE server_config SET char_prop_value='arcsdeserver,100,ecpYOUR_ArcSDE10_CODE,none,YOUR_ArcSDE10_CODE' WHERE prop_name = 'AUTH_KEY';
So, as the things are going badly, this is how it is going to be:Since the ArcGIS Desktop is here used as a base form some Utillity Extension, I will create a new empty gdb, create new SDE user and repository, and use the extensions tools to export/upgrade the data and then bulk load it back to the ArcSDE.I do not see any other solution....I just give up, since I have an alternative...not a better one, but an usable one.
There is something very wrong in the way upgrades are ment to be performed, or in the software configuration that was asked from the extension manufacturer, or maybe in the position of the stars for the past two weeks that I have lost doing this. 🙂
It seems that we think alike, Vince 🙂I didn't give up, instead I decided to follow this manual:http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Migrating_to_ArcSDE_64_bit_on_Windows_when_the_existing_DBMS_is_32_bit/002n000000q0000000/I deleted the geodatabase, created a new one, empty, and installed ArcSDE from the scratch...created the repository, user and voila....the authorization passed without a glitch. So it wasn't the license code...Then, I created the service, started also without problems.
Everything went well, with minor stops because of the relationship classes and extensions, privileges, roles creation etc...but now I get the error in the attach, and do not know what it is: [ATTACH=CONFIG]24308[/ATTACH]Any ideas?Tnx,M.
I have contacted the local ESRI dealer, and they will come to assistance today, since they are but busy......It seems that now everything works... I have copied everything, and all the data is now on Oracle 11g under SDE 10 SP5.
Thanks to you guys, your suggestions saved me.P.S. If I run into more troubles, I'll come back 🙂
