layer = new esri.layers.WMSLayer(lay.url); layer.setVisibleLayers([lay.catalog]); layer.setImageFormat("png"); layer.spatialReference = new esri.SpatialReference({wkid:102100}); layer.layerInfos= new esri.layers.WMSLayerInfo({name:lay.label,title:lay.label}); layer.version= "1.1.1"; layer.id= lay.id;
using api 3.2 layer = new esri.layers.WMSLayer(lay.url); layer.setVisibleLayers([lay.catalog]); layer.setImageFormat("png"); layer.spatialReference = new esri.SpatialReference({wkid:102100}); layer.layerInfos= new esri.layers.WMSLayerInfo({name:lay.label,title:lay.label}); layer.version= "1.1.1"; layer.id= lay.id; For some reason the request is failing occassionally (inconsistently) because the URL does not include the SRS/CRS (i tried 1.3.0 as well).FAILShttp://www.mymanatee.org/lizardtech/iserv/ows?SERVICE=WMS&REQUEST=GetMap&FORMAT=image/png&TRANSPARENT=TRUE&STYLES=&VERSION=1.1.1&LAYERS=1978&WIDTH=1600&HEIGHT=791&BBOX=-9233714.17262806,3140877.1703132535,-9111414.927371942,3201338.8596867467WORKShttp://www.mymanatee.org/lizardtech/iserv/ows?SERVICE=WMS&REQUEST=GetMap&FORMAT=image/png&TRANSPARENT=TRUE&STYLES=&VERSION=1.1.1&LAYERS=1978&WIDTH=1600&HEIGHT=791&BBOX=-9233714.17262806,3140877.1703132535,-9111414.927371942,3201338.8596867467&SRS=EPSG:102100all i did was manually add the SRS at the end. But i cannot do this in my code, since its just a navigation event requesting a new tile?
var wmsLayer = new esri.layers.WMSLayer("http://www.mymanatee.org/lizardtech/iserv/ows"); wmsLayer.setVisibleLayers(["1940"]); map.addLayer(wmsLayer);
its a wms layer call
i did the manual layer definition when there where wms errors around 2.8/3.0 . I will try the other way.
var wmsLayer = new esri.layers.WMSLayer("http://www.mymanatee.org/lizardtech/iserv/ows"); dojo.connect(wmsLayer, "onLoad", function (lyr) { dojo.forEach(lyr.layerInfos, function (info) { if (info.name){ map.addLayer(new esri.layers.WMSLayer( lyr.url, { visibleLayers: [info.name], //Providing resourceInfo prevents an unnecessary GetCapabilities request resourceInfo: { extent: lyr.extent, layerInfos: lyr.layerInfos, version:lyr.version } }) ); } }); });
It is usually connect to one wms, switch to another and it fails.
i copied the failing uri out of firebug so I am sure that was the request being made.
i saw this comment in your code//Providing resourceInfo prevents an unnecessary GetCapabilities requestcan you elaborate?
If resourceInfo is specified a GetCapabilities request is not executed
I unset alot of properties, not only does it seem to help, but it seems to have sped it up?!
would you be willing to share your class?
In particular i am looking to try to make tiled requests of the WMS service.
I have been told express server (lizardtech) supports this if the request is made properly.
thanks again for all the help and guidance!
