Kde najdu jednoduché "jak na to" otázky pro ArcGIS Pro? Dříve jsem mohl kliknout na nápovědu v ArcMap, ale tuto možnost nevidím v ArcGIS Pro.<\/P><\/BODY><\/HTML>
About ArcGIS Pro Help—ArcGIS Pro | Documentation
check to see if you are using online or downloaded help
Hi Joseph,
You can click on the ? icon in the upper right hand corner of the ArcGIS Pro application to open up the help pages. Installed help (offline) or web help (online) will open depending on your General settings under Option.
Cheers,
Jonah
