I am using OSM map in arc GIS java Runtime Application. How can I convert OSM map point to simple map points or Simple map point to OSM map points. For example
OSM map points: lat=734564 lon=312546 After conversion lon=31.54344 lat=73.157476.
You may want to start my looking at the project() method on the GeometryEngine object.
GeometryEngine (ArcGIS_Runtime_Java 10.2.4 API)
You'll need to know the spatial reference of the point from OSM and the spatial reference you want to convert the point to.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
