Hi Jeff, Thank you for your feedback. We have fixed this issue by validating add-in's digital signature using time stamp and the fix will be in the coming ArcGIS 10.0 SP2. You also got a crash when re-running ESRISignAddIn.exe on a previously signed add-in. We'd like to know your steps since we couldn't reproduce this issue.Thanks!Xiaoling
diegollamas:On a 32-bit PC with a default ArcGIS for Desktop installation and the SDK for .NET installed, the ESRISignAddIn.exe utility can be found at C:\Program Files\Common Files\ArcGIS\bin. I am not sure if the SDK is required or not, but if you can't find the utility, it may be the reason.jeffhamblin has posted the location of this utility on 64-bit PCs in this thread as well.Good luck,Dennis
