Elizabeth, So you have tested the Query at the REST End point just like I said in my last post (not just in ArcMap)?... I actually have never tested a SDE View Join in my widget so it might be an issue there...
<value prompt="Example: Owner: " isvaluerequired="true" operator="AND">upper(santarosagis.GISADMIN.QS36F_SRVIEW1.OWNER_NAME) LIKE upper('%[value]%')</value>
Elizabeth, What you sent is the zip is not the eSearchWidget.xml...
<layers/> <tables> <table> <token/> <definitionexpression/> <enableexport>true</enableexport> <enableprintgrid title="Selected Owners">true</enableprintgrid> <name>Owner Name Search</name> <url>http://192.1.1.163:6080/arcgis/rest/services/MyMapService/MapServer/5</url> <expressions> <expression alias="Owner_Name" textsearchlabel="Search Owner Last Name:" isvaluerequired="true"> <values> <value prompt="Example: Owner: " isvaluerequired="true" >upper(OWNER_NAME) LIKE upper('%[value]%')</value> </values> </expression> </expressions> <titlefield>OWNER_NAME</titlefield> <fields all="true"/> <links/> <queryattachments>false</queryattachments> <relates/> </relates> </table> </tables>
if(layerDetails && field){ var typeID:String = null; if (layerDetails.typeIdField && fieldName.toUpperCase() == layerDetails.typeIdField.toUpperCase()){ typeID = layerDetails.typeIdField ? graphic.attributes[fieldName] : null; // replace value with feature type name var featureType:FeatureType = getFeatureType(typeID); if (featureType && featureType.name){ value = featureType.name; } }else{ // replace value with coded value name if one exists var codedValue:CodedValue = getCodedValue(fieldName, value, typeID); if (codedValue){ value = codedValue.name; } } }
for each (fld in _layerDetails.fields){ var typeID:String = null; if (_layerDetails.typeIdField && fld.name.toUpperCase() == _layerDetails.typeIdField.toUpperCase()){ typeID = _layerDetails.typeIdField ? attributes[fld.name] : null; // replace value with feature type name var featureType:FeatureType = getFeatureType(typeID,_layerDetails); if (featureType && featureType.name){ attributes[fld.name] = featureType.name; } }else{
for each (fld in _rlayerDetails.fields){ var typeID:String = null; if (fld.name == _rlayerDetails.typeIdField){ typeID = _rlayerDetails.typeIdField ? String(attributes[_rlayerDetails.typeIdField]) : null; // replace value with feature type name var featureType:FeatureType = getFeatureType(typeID,_rlayerDetails); if (featureType && featureType.name){ attributes[fld.name] = featureType.name; } }else{
<layer> <token/> <definitionexpression/> <enableexport>true</enableexport> <name>Parcels</name> <url>your url here</url> <expressions> <expression alias="PIN" textsearchlabel="Search by Parcel ID Number (PIN):" isvaluerequired="true"> <values> <value prompt="Example: 3072504001001000" isvaluerequired="true" autosubmit="false">PIN = '[value]'</value> </values> </expression> </expressions> <graphicalsearchlabel>Use one of the graphical search tools to select a Parcel</graphicalsearchlabel> <spatialsearchlayer>true</spatialsearchlayer> <titlefield>OWNERNAME</titlefield> <fields all="false"> <field name="PIN" alias="Parcel ID" gridfield="true"/> <field name="OWNERNAME" alias="Owner" gridfield="true"/> <field name="MAILADDR" alias="Mailing Address" gridfield="true"/> <field name="LEGALDESC" alias="Legal Description" gridfield="true"/> <field name="PropNum" gridfield="true"/> <field name="PropDir" gridfield="true"/> <field name="PropStrt" gridfield="true"/> <field name="COMMENTS" alias="Additional Info" gridfield="true"/> </fields> <links/> <zoomscale usegeometry="true" zoompercent="2"/> <autoopendatagrid>true</autoopendatagrid> <queryattachments>false</queryattachments> <relates /> <symbology> <simplefillsymbol color="0xff0000" alpha="0.5"> <outline color="0xff0000" alpha="0.8" width="2"/> </simplefillsymbol> </symbology> </layer>
<defaultselectionoption>textInput</defaultselectionoption><!--possible values only one graphicalInput or textInput or spatialInput -->The defaultselectionoption element is a string that specifies which search option (i.e graphicalInput or textInputor spatialInput) will be the default search option for the widget.
Josh, I don't have any real suggestions on your data with carriage returns in it...As far as the initalview thing the Enhanced Search Widget XML Configuration.pdf tell you the tag for that.
