I just started using ArcScene and managed to detach the main menu from the dock and then accidentally closed it. I've tried double clicking on the grey area and checking the customize window to see if the Main Menu is checked, but it no longer shows up in this window (See the attached image). I would really appreciate the help.
Thanks!
Cami
I would look in this case to reset your Esri Profile.
Close ArcScene/ ArcMap
Open Windows Explorer (Enable the viewing of hidden files)
Browse to %\Users\<USERNAME>\App Data\Roaming\ESRI
Rename the folder that is Esri to Esri_OLD
Open ArcScene again and it should be visible
(Note any folder connections/ db /server connections will need to be remade again)
Cheers
Thank you so much John. That fixed my problem within under a minute.
Great - to help close the thread if you mark my answer as correct this will show users that the issue has been resolved
Have a good week ahead
