Are any of your feature classes existing in ArcGIS Server services? The services will need to be shutdown in order to remove the locks. Also, does the geodatabase contain any replicas? These will need to be synchronized before the compress.
I have a feature class with the name GIS_POLYGON_TEST.Versions:sde.defaultsde.TestAfter opening ArcMap and adding the FeatureClass I want to work, I'm following the steps bellow:-> create version-> start editing-> add a polygon -> reconcile and post version -> save and stop edition -> delete the test version -> run compressTable 'A' of GIS_POLYGON_TEST is not cleared.*The dataset is versioned.what's the problem?
