arcpy.gp.RasterCalculator_sa("\"%Temp4%\"/2", Temp2)
according to the help, the raster calculator is for use inside arcmap only, for calculations in python you should use mapalgebra:http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z000000z7000000.htm
import arcpy, os, sys, stringfrom arcpy import envfrom arcpy.sa import *arcpy.CheckOutExtension("spatial")arcpy.env.workspace = r'O:\DATA\test'InputFolder = arcpy.env.workspaceTemp4 = InputFolder + '\\' + temp4RasterList = arcpy.ListRasters() for RasterImage in RasterList: Temp4 = FocalStatistics('RasterImage', NbrRectangle (9, 9, 'CELL'), "RANGE", "DATA") print ('Focal Statistics').....
