I am new to arcgis, We are developing an offline application using WPF ( runtime : 10.2.7 ). How can draw smooth polylines? I am attaching an image which shows polylines, but it looks not good, It would be better if it has smooth lines.
Sorry for my english.
Thanks in advance.
siva
You're using ArcGIS Runtime SDK for .NET - I moved your post to this forum. Also, instead of using 10.2.7, if possible I would recommend upgrading to the v100 series (v100.1 just released). There isn't a specific line smoothing function in the API currently, but you might find the GeometryEngine Generalize operation provides the desired effect?
v100.1: GeometryEngine.Generalize Method
v10.2.7: GeometryEngine.Generalize Method
Cheers
Mike
Thank you Mike.
