Is there anyway to add an Export to CSV button on each layer of the Near Me widget to export the filtered data sets ?I tried to adapt the PopUpMenu button from the Select widget but I didn't find a way to make it.
Further, when the widget creates it's buffer, selection should be visible along with the choice to export to CSV. OR....add a distance button to the Selection Widget seeing that it already has the export function. So, you can draw a circle at a specific radius or maybe just let the tool 'report' it's distance or area as you move your mouse for approximation?
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
