Thank you SaultDon,Unfortunetely, there are no shared attributes. However, one attribute is the name of the feature. Names look like "Line1 A", "Line1 B", "Line1 C",...,"Line2 A", "Line2 B", "Line2 C",...So, the idea is to combine all small lines (features) "Line1 %" into a single line (feature) "Line1". Similar to all other lines - one "Line2", one "Line3", etc
Left([LineName], 5)
Trim([NewLineName])
I'm not sure if I should start a new thread...The next challenge is to delete "unnecessary" points from which a new dissolved line consist.I would like to leave only joint points (points where the line changes the direction). Now, the straight line could contain like 200 points, whereas it can be built by 2.Is there a way to get rid of these "unnecessary" points.Thank you in advance.
