Why would a hosted point feature layer with less than 100 points and no attachments take 9GB?
We do edit the feature layer a lot.
@rachelg_esri wrote:If you temporarily disable the syncing, then re-enable it, you effectively clear out those tables.
Hi Rachel,
Thanks for the advice — I now understand why my empty FHS were so large in size.
WRT disabling the sync — this is a good idea, but the trouble is if the FHS has been taken offline in FieldMaps/Collector, it won't sync again even if you've re-enabled sync on the FHS. There is a warning: Unable to synchronise replica (because it's been removed!).
I've been investigating a method to update a very large, sync-enabled, FHS. While it is possible to do so using the ArcGIS Python API (delete rows & append), I'm always going to have the problem of every growing replicas.
So, going back to the drawing board, I think creating a MMPK or a VTPK is the way to go.
Prepare maps for download—ArcGIS Field Maps | Documentation
disable sync warning message
Sync failed message in Windows Collector
It was the syncing. Decided to turn it off permanently. Was not a definite requirement to go offline.
Went from 9GB to 0.4MB 🙂
Thanks
Hello Peter!
Syncing is the one I worry the most about the list above, given your results. Sync tables are not directly visible in the hosted feature service, and are back-end tables. Whenever a device with the data goes offline (Collector offline usage, for example), the back end tables are keeping track of a lot of information about what rows are being used by what users. Over time, those sync tables can get pretty big.
If you temporarily disable the syncing, then re-enable it, you effectively clear out those tables. I'd choose a time when you know no one will be accessing/using the feature service, then flip that toggle (make sure everyone's checked back in first!). Then see if the size drops.
Here's a bit of information on Syncing at the following link (scroll to the "Allow offline editing or collaboration" section):
ArcGIS Online: Manage Hosted Feature Layers
Let us know if that helps?
Thank you!
Best regards,
Rachel
Esri Support Services
So one of those options affect size? Is there archiving somehow?
There could be a few things at play here:
Let me know if you need help finding any of this.
Thanks!
