Have you tried current version of Android Collector (10.3.3)? It should have this capability. If you are using iOS, you will get this capability in the coming version.
Hi Russell,
Any idea when this will be solved as it works in WebApp - I have surveyors that need to jot coords down on crib sheet for specific surveys.
Thanks
Gideon
Hi , thanks - I am having problems with refresh on Collector so it did not appear to be working. Now it is fine.
Hi guys.
Is there a way to have the map coordinates in "Collector" displayed and registred in a projection other than geographic wgs84?
I need the coordinates and attributes are displayed and recorded in UTM projection. How should I proceed?
Thank you,
Marcos Almir
Hi Russell - is this still the case?
Could there at least be an option to change the format of the Lat Long display or display all three (3) formats?
Ideally would also have local projected co-ordinates.
