For a given month I would like to know how many users connected, which maps or apps were used by how many users etc.
Is the 'My Organisation" tab the only way or is it possible to download the data?
Jürgen
Hi Jürgen,
When you say "the 'My Organisation' tab", if you are referring to the Activity Dashboard capability in Portal for ArcGIS, then yes - this is the current best means to get information on how your Portal is being used; by how many different Portal members; which items are the most popular, etc.
About usage reports—Portal for ArcGIS (10.3 and 10.3.1) | ArcGIS for Server
Another option is to write custom scripts using PortalPy to query for the information you're looking for.
Scripting administrative tasks with PortalPy—Portal for ArcGIS (10.3 and 10.3.1) | ArcGIS for Server
We are always looking to enhance the reporting capabilities in Activity Dashboard. If you have feedback and enhancement suggestions, please let us know.
Hope this helps,
Hi Derek,
Thanks for your post here, I am also trying to get the user usage statistics like, how many users has logged in ArcGIS Portal. but the problem I am facing is that browser save the user credentials in the cache and user do not need to enter their login credentials again. due to that we are not able to record the login information. in the logs it is showing that the user logged only once. do we have any solution for this?
Hi Salman,
> I am also trying to get the user usage statistics like, how many users has logged in ArcGIS Portal. but the problem I am facing is that browser save the user credentials in the cache and user do not need to enter their login credentials again. due to that we are not able to record the login information. ... do we have any solution for this?
The only usage information we store in Portal for ArcGIS is when a user last logged into Portal. If the browser has cached the user's credentials, we will not log this as a login event as far as I'm aware.
Please post an enhancement request on the ArcGIS Ideas site, ArcGIS Ideas
Is there a way to export usage as a pdf from portal 10.6.1. I have opened the "VIEW STATUS" link and those statistics are handy but I'm not sure if i can export those statistics.
Hi Health,
Sorry for the late reply. I am in the process of trying to track down an answer for you. Will post more when I have an update.
Thanks for your patience,
Apologies for the late follow up. It took some time to track down an answer on your question.
> Is there a way to export usage as a pdf from portal 10.6.1...
From the Dev team, "We do not expose the usage statistics used on the 'status' page. You can gather general statistics using the User object, Item object, Item.usage() and gis.admin.history() via custom scripts with the Python API. Some users will store these daily statistics in a hosted table and aggregate the data to fit their needs."
Hope this helps and thanks for your patience,
Thank you. I'll take a look at doing that.
I also did monthly tracking of the number of times each of our apps was viewed. Now we're in Portal and I can't figure out a way to do it
Are you using Google Analytics to track usage?
I have a similar request. Is there a way to get user statistics in AGE Portal? I would like to see the users that accessed portal on a monthly base and how often they accessed Portal or items (apps, maps etc.) in Portal. I was wondering if such user data are stored in a database and how I can access this database?
