Can I use Web AppBuilder for ArcGIS to build web-mapping apps without using ArcGIS Online like ArcGIS Viewers for Silverlight and Flex? Or is it an ArcGIS Online-dependent application builder?
Hani,
The answer is YES, IF the following conditions are meet.
Hope this clearly answers your question.
Currently the Web AppBuilder depends on a WebMap from AGOL. But there is a widget available to add your own map services along as your basemap comes from an AGOL web map.
Thank you Robert,
Can I install the builder on my machine to build the apps, or should I access my ArcGIS organizational account to build them?
Does the Web AppBuilder consume services published from ArcGIS Server? or just those hosted by ArcGIS Online
There is a Web AppBuilder Developer Version you can install on your local machine to build the apps.
Web AppBuilder for ArcGIS | ArcGIS
As I mention in my last reply Currently Web AppBuilder consumes a WebMap hosted by ArcGIS Online. But there is a widget available to add your own map services along as your basemap comes from an AGOL web map.
Robert,
I got confused about your second answer, I used the map tab but seems that I cannot add any service published by ArcGIS Server, all the available options are for services from AGOL (please see the first screenshot).
In addition, I could not find any widget to add services (please see the second screenshot, do you mean the “map” tab in the first screenshots?)
Please provide me with a YES/NO answer to this question: Can I add a service published from ArcGIS Server to an app built with WebApp Builder?
