prosím, potřebuji pomoc. Může mi někdo říct, jak vypočítat plochu pokrytou každou z těchto tříd hustoty obyvatelstva znázorněných barvami RED, GREEN, BLUE a BROWN pomocí ArcGIS ArcMap. děkuji <\/P><\/BODY><\/HTML>
Hi Attai,
Tabulate Area should give you what you need, assuming you have the Saptial Analyst extension: ArcGIS Help 10.1
Hi Attai, I just noticed you asked a different question recently with the same title: hi everyone. You received several helpful seeming answers, but there is no reply from you as to whether they answered your question. Please remember a few things... First, GeoNet is designed as a resource that others can search to find similar questions that have been answered. This only works well if people take the time to close out their questions properly. Second, people put a lot of volunteer time and energy into looking for solutions to others' questions. Please take the time yourself to respond, and mark their answers as helpful or correct, if that was the case, or even to say why the answer didn't work for you. Thanks.
thanks your assistance was helpful. problem solved
That's great! Do you mind saying how the problem was solved? You can mark an answer a correct, or if you found the solution some other way, you can just state the solution you found as mark that as correct. Thanks in advance!
