package org.lacsd.services.helpers; import java.io.IOException; import java.net.UnknownHostException; import com.esri.arcgis.system.AoInitialize; import com.esri.arcgis.system.EngineInitializer; import com.esri.arcgis.system.esriLicenseProductCode; import com.esri.arcgis.system.esriLicenseStatus; public class LicenseHelper { /** * Initializes the lowest available ArcGIS License */ public static AoInitialize initializeArcGISLicenses() { EngineInitializer.initializeEngine(); AoInitialize aoInit = null; try { aoInit = new AoInitialize(); } catch (UnknownHostException e) { // TODO Auto-generated catch block e.printStackTrace(); } catch (IOException e) { // TODO Auto-generated catch block e.printStackTrace(); } try { System.out.println("license type: " + esriLicenseStatus.esriLicenseAvailable); if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeEngine) == esriLicenseStatus.esriLicenseAvailable) { aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeEngine); } else if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeArcServer) == esriLicenseStatus.esriLicenseAvailable) { aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeArcServer); } else if (aoInit.isProductCodeAvailable(esriLicenseProductCode.esriLicenseProductCodeArcInfo) == esriLicenseStatus.esriLicenseAvailable) { aoInit.initialize(esriLicenseProductCode.esriLicenseProductCodeArcInfo); } else { System.err.println("Could not initialize an Engine or ArcView license. Exiting application."); System.exit(-1); } // do any extra checkouts here, could probably expand to make sure extension available // aoInit.checkOutExtension(com.esri.arcgis.system.esriLicenseExtensionCode.esriLicenseExtensionCodeNetwork); } catch (Exception e) { e.printStackTrace(); } return aoInit; } }
VersionManager vm = new VersionManager(); vm.loadVersion(com.esri.arcgis.version.esriProductCode.esriArcGISDesktop, "10.0");
It seems that the code in AoInitialize has some dependencies that don't like when you are pointing to an arcobjects.jar file that is not in the standard location. I had bundled the jar file in a war file that was deployed to a particular location but that caused me to have all sorts of problems. I removed the arcobjects.jar file from my war file and added the bootstrapping code that I eventually stumbled across on this site and have been able to successfully initialize my license. Now on to my next issue...
