We have Win 7 and XP machines. I tested both and didn't get the crash.
TedThese 2 ESDA tools creates "dots" on the graph, where each dot represents what happens between 2 points. The number of points in the graph can be calculated by computing n(n+1)/2, where n=number of points. We have done testing and determined that n=500 is sufficient, i.e. 125,250 dots on the graph. Using more than 500 points really does not tell you much more, so we decided to warn you each time. n=1000 will create half a million dots, will you learn any more than if you used n=500?A rule of thumb when doing ESDA is to create a subset (use the CreateSubsets GP tool) if you're using a large dataset. 1000 is large when talking to geostatisticians.I cannot repro the crash.Hope this helps and thanks for testingSteve
