Help me! I don't use identify task with feature layer
ex:
IdentifyTask identifyTask = new IdentifyTask("http://localhost:6080/arcgis/rest/services/Dak_Nong_Thuy_He_100k/FeatureServer");
identifyTask.ExecuteCompleted += IdentifyTask_ExecuteCompleted;
FeatureLayer doesn't support 'Identify'.
As the features are loaded at client side, you don't need to request the server to get info about the features.
You can use a MapTip instead. This will work locally.
Thanks!
2015-03-18 18:17 GMT+07:00 Dominique Broux <geonet@esri.com>:
don't use identify task with feature layerreply from Dominique Broux<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo7A4BXwO9PY1WvQ5cXCtK48l6pSGrfmxMREdVDxGWMeEYCwHIuz7sFk-2FNkwO3-2FrAJxMPHb0pcEXlEYU0lgy5kK4-3D_mzFln438K2aMszPWkSHJEv7hUPXHwJQCCzrFhP0edbEwVg7p0M45tn-2BSBNhzBLPJcqtfHwuk1UuR9mML-2FdIsY4DB2c5C3BcFKLho9qBiJsenHnG-2BeDhYaMQ46JRzLrPertTLqxsDofGDYXGMcn7vMn-2BJNMQjdPSdXZbhywgbzg3O46bALo3ZEa7LRkv8orNgvjHagS-2ByrI7qGBPe5j6elYFh9FtL0WQCfrqkeNzgIpIDbsPVyxrM-2Fbv0x2E42Uvfcd59sNpbLr0yCRHWw78eqn9Iu-2FM5Jcl37QTdVF5IXZnw2n6K6nJA3dcbRDf8jVohCRYqdWWcacb5hqwntXUZBQ-3D-3D>in ArcGIS API for Silverlight - View the full discussion<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo0VQjeJBYpG9HGC8QZBT-2FEyNvlvNC7zAii-2FPRTy4h1A90bZ7bj8CY4J2-2BUH-2FEYlzbpi-2Fe3LE0l1x5WoU5RL4NSw-3D_mzFln438K2aMszPWkSHJEv7hUPXHwJQCCzrFhP0edbEwVg7p0M45tn-2BSBNhzBLPJcqtfHwuk1UuR9mML-2FdIsY4DB2c5C3BcFKLho9qBiJsenHnG-2BeDhYaMQ46JRzLrPertTLqxsDofGDYXGMcn7vMqBYPeIKw-2B-2F4aCt-2Bcozf8Vz7rp6Fgvp7dZX9gB460vFKWpPBTd0-2Ftxp29StjBTZMBiCuZOjdBOaZFpCUuh5J9U-2FtuF2Xuyr2ijcJTulSpzVrC-2BuCcO5FjnTCDa0ciElKAlJa2GNltjIq88ssW1du4CnGpTqs3p7YAmxs-2FyEygkHIcfhDf8ddxkJqiFUKP1Q5TA-3D-3D>
