<esri:PictureMarkerSymbol id="markerSymbol" source="images/star.png" height="25" width="25"/> <esri:WeightedClusterer id="clusterer" symbol="{markerSymbol}"/>
Drew, Actually it does.http://thunderheadxpler.blogspot.com/2010/08/image-flare-symbol-for-clustered.html
It's actually working as expected. The cluster is turned into a single Graphic and it's being drawn using the given symbol. Any other behavior depends on the symbol that is used.
Yes, that should work. The cluster would be represented by the star. What's happening when you try this?
