<layer label="Fires" type="feature" visible="false" alpha="1.0" popupconfig="popups/PopUp_Fires.xml" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0"/>
token�??Token value used for accessing secured ArcGIS Server services. Only applies to layers coming from ArcGIS Server, that is, dynamic, feature, image, or tiled.
<layer label="Fires" type="feature" visible="false" alpha="1" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0"> <uniquevaluerenderer field="type" fielddelimiter=","> <uniquevalueinfo value="3" label="Campground"> <picturemarkersymbol url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0/images/4A138C60" height="20" width="20"/> </uniquevalueinfo> <uniquevalueinfo value="2" label="Contained Fire"> <picturemarkersymbol url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0/images/7D8E714C" height="20" width="20"/> </uniquevalueinfo> </uniquevaluerenderer> </layer>
<layer label="DMVA Inactive" type="feature" visible="false" alpha="1" url="https://www.oagisargissvr.beta.state.pa.us/ArcGIS/rest/services/DMVA_SAFER_AVL/MapServer/2?token=mq3pMZuiWDvMpOJeYoE5XbrWLwLpYVGB4dKeQxzfW7gVtL_YSLqs-YFM7pF8zPqffMWeBU83wjtHuFEm436NgA.."> <uniquevaluerenderer field="TYPE"> <uniquevalueinfo value="HMV" label="HMV"> <picturemarkersymbol height="20" width="20" url="assets/images/Sleet.png"/> </uniquevalueinfo> <uniquevalueinfo value="Transport" label="Transport"> <picturemarkersymbol height="20" width="20" url="assets/images/Ice.png"/> </uniquevalueinfo> </uniquevaluerenderer> <popupconfig="popups/BFT/800MHz.xml"/> </layer>
<layer label="Fires" type="feature" visible="false" alpha="1" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0"> <uniquevaluerenderer field="type" fielddelimiter=","> <uniquevalueinfo value="3" label="Campground"> <picturemarkersymbol url="assets/images/es.png" /> </uniquevalueinfo> <uniquevalueinfo value="2" label="Contained Fire"> <picturemarkersymbol url="assets/images/fr.png" /> </uniquevalueinfo> <uniquevalueinfo value="4" label="Damaged Home"> <picturemarkersymbol url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0/images/7D11DE72" /> </uniquevalueinfo> <uniquevalueinfo value="0" label="Fire Department"> <picturemarkersymbol url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0/images/86A29AC1" /> </uniquevalueinfo> <uniquevalueinfo value="6" label="Mountain"> <picturemarkersymbol url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0/images/41B1D33E" /> </uniquevalueinfo> <uniquevalueinfo value="5" label="Ranger Station"> <picturemarkersymbol url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0/images/EEA508E3" /> </uniquevalueinfo> <uniquevalueinfo value="1" label="Shelter"> <picturemarkersymbol url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0/images/B0F5149C" /> </uniquevalueinfo> </uniquevaluerenderer> </layer>
<layer label="DMVA Inactive" type="feature" visible="false" alpha="1" url="https://www.oagisargissvr.beta.state.pa.us/ArcGIS/rest/services/DMVA_SAFER_AVL/MapServer/2?token=mq3pMZuiWDvMpOJeYoE5XbrWLwLpYVGB4dKeQxzfW7gVtL_YSLqs-YFM7pF8zPqffMWeBU83wjtHuFEm436NgA.."> <uniquevaluerenderer field="TYPE" fielddelimiter=","> <uniquevalueinfo value="HMV" label="HMV"> <picturemarkersymbol height="20" width="20" url="assets/images/excel.png"/> </uniquevalueinfo> <uniquevalueinfo value="Transport" label="Transport"> <picturemarkersymbol height="20" width="20" url="assets/images/ru.png"/> </uniquevalueinfo> </uniquevaluerenderer> <popupconfig="popups/BFT/800MHz.xml"/> </layer>
case "feature": { var featureLayer:FeatureLayer = new FeatureLayer(url); featureLayer.addEventListener(FlexEvent.HIDE, featureLayer_hideHandler); featureLayer.alpha = alpha; featureLayer.id = label; featureLayer.name = label; featureLayer.maxAllowableOffset = maxAllowableOffset; featureLayer.outFields = [ '*' ]; // TODO: be smarter featureLayer.token = token; featureLayer.visible = visible; featureLayer.useMapTime = useMapTime; featureLayer.clusterer = clusterer; if (useAMF) { featureLayer.useAMF = (useAMF == "true"); } if (mode) { featureLayer.mode = mode; } if (definitionExpression) { featureLayer.definitionExpression = definitionExpression; } if (proxyUrl && useProxy) { featureLayer.proxyURL = proxyUrl; } // example for hard-coding layer symbology, e.g. for pre-10.0 ArcGIS Servers /* if (label == "Traffic Cameras") // the layer label in main configuration file { var picSymbol:PictureMarkerSymbol = new PictureMarkerSymbol("assets/images/i_camera.png",30,30,0,0,0); var rend:Renderer = new SimpleRenderer(picSymbol); featureLayer.renderer = rend; } */ //Added Code if(label == "DMVA Inactive"){ var picSymbol:PictureMarkerSymbol = new PictureMarkerSymbol("assets/images/excel.png",30,30,0,0,0); var picSymbol2:PictureMarkerSymbol = new PictureMarkerSymbol("assets/images/ru.png",30,30,0,0,0); var infoArr:Array = []; var uvVal1:UniqueValueInfo = new UniqueValueInfo(picSymbol,"HMV"); infoArr.push(uvVal1); var uvVal2:UniqueValueInfo = new UniqueValueInfo(picSymbol,"Transport"); infoArr.push(uvVal1); var uvRend:UniqueValueRenderer = new UniqueValueRenderer("TYPE",null,infoArr); featureLayer.renderer = uvRend; } //End Added Code layerObject.layer = featureLayer; featureLayer.addEventListener(LayerEvent.LOAD_ERROR, layer_loadErrorEvent); featureLayer.addEventListener(LayerEvent.LOAD, layer_loadEvent); map.addLayer(featureLayer); break; }
import com.esri.ags.renderers.UniqueValueRenderer; import com.esri.ags.renderers.supportClasses.UniqueValueInfo;
