many times to switch from the map,system jammed
Hi wythe_hi,
What is the crash statement or error message that you are getting?
Can you be a little more explicit in what exactly you are doing? Are you finding the crash after certain method calls or something else?
Do you find that it crashes with a certain map?
Alexander
Thank you for your reply,our app has no error log,I load tile map online used the "ArcGISTiledMapServiceLayer" and “GraphicsLayer” layer,then we start-up arcgis map mode many times,system no response,so I do not know why.
