Is there a limit in the number of layers you can add into a story-map? I have included about 20 layers in the web-map but only
... but only 11 are listed in the map content. Thanks in advanced for any tip...
Should not be, could you share a link to your app and/or the webmap that is causing you the issue?
Thanks
Hello Marco,
Are you using the map builder or a story map app?
Amanda
