<esri:PrintParameters id="printParameters" format="{formatsDDL.selectedItem}" layoutTemplate="{layoutTemplatesDDL.selectedItem}" map="{hostBaseWidget.map}" preserveScale="{scaleCheckbox.selected}"> <esri:layoutOptions> <esri:LayoutOptions id="layoutOptions"> <esri:scaleBarOptions> <esri:ScaleBarOptions nonMetricUnit="esriFeet"/> </esri:scaleBarOptions> </esri:LayoutOptions> </esri:layoutOptions> </esri:PrintParameters>
You'll need to set PrintParameters.layoutOptions.scaleBarOptions.nonMetricUnit.See:http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/tasks/supportClasses/ScaleBarOptions.html
You would need to recompile the PrintWidget with this change to the PrintParameters inside ExportWebMapForm.mxml: <esri:PrintParameters id="printParameters" format="{formatsDDL.selectedItem}" layoutTemplate="{layoutTemplatesDDL.selectedItem}" map="{hostBaseWidget.map}" preserveScale="{scaleCheckbox.selected}"> <esri:layoutOptions> <esri:LayoutOptions id="layoutOptions"> <esri:scaleBarOptions> <esri:ScaleBarOptions nonMetricUnit="esriFeet"/> </esri:scaleBarOptions> </esri:LayoutOptions> </esri:layoutOptions> </esri:PrintParameters>
