There isn't a hard limit on the number of facilities you can use. The problem you're probably having is that using more facilities generates a longer URL. When the API tries to load a URL over 2048 characters, it automatically switches to doing a POST instead of a GET. Doing a POST with a long URL requires a proxy page due to limitations imposed by some browsers. It's pretty straightforward to set up a proxy page. We have instructions on how to do this in the proxy page documentation.
We have the proxy page correctly set up on our site and I still have never gotten this task to work, particularly over long distances. Is it meant to be a short-range solution?
Does it time out does it return an error? And are you able to get the same request to work from the services directory?
"code":400,"message":"Unable to complete operation.","details":["No \"Facilities\" found for \"Location 1\" in \"Incidents\". No solution found
