Enabling popups is exposed on the sub-layers of a service layer. So you need to expand the layer by clicking on it to expose the sub-layers. The popup options are on the context menu of the sub-layers. Popups are not supported on image service layers.If you don't see the popup options it may be that the "shape" field of the service layer is hidden. You can check on the service layer by clicking on the Description option in the context menu for a sub-layer. You should see a page like this:http://atlas.resources.ca.gov/ArcGIS/rest/services/GeoScience/California_Fire_History/MapServer/1Look at the Fields section to see if Shape field is visible. If it isn't then you can't enable popups. However, if you control the service itself, you can enable the shape field and refresh the service.Thanks,Mike
So true Mike! Getting people to use the help is like pulling teeth!
Hello Mike,Of course, now it doesn't work and I see from this thread that the shape can't be hidden. When did this change take place?
