Patricia, OK so let me get a few quick questions answered from you then.Do you see the fixed datagrid in your app?When you go to http://192.168.100.102/ArcGIS/rest/services/Signs/MapServer/0 in your web browser do you see Relationships list almost completely at the bottom of the page and do you see the query related records link?Are you saying that the SearchWidgetFixedDG.xml was not in your download?...
<widget right="0" left="0" bottom="0" config="widgets/eSearch/SearchWidgetFixedDG.xml" url="widgets/eSearch/SearchWidgetFixedDG.swf"/>
<floatorfixed disablerelatestabinfixed="false">float</floatorfixed><!-- possible values are fixed and float -->
<fields all="false"> <field name="OnStreetName" alias="Street Name" gridfield="true"/> <field name="Subtype" alias="Post Type" gridfield="true"/> <field name="FACILITYID" alias="Post ID" gridfield="true"/> <field name="PCond" alias="Post Condition" gridfield="true"/> <field name="SonPost" alias="Signs on Post" gridfield="true"/> </fields>
<fields all="true" />
<fields all="True"/>
<fields all="true"/>
However, the relate is working just can't open the images using the hyperlinkgridfield
