Hi all,I'm following this example (but programmatically) http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/find_map_datagrid.htmland I don't know why my graphic are not showing up...Thank's for your help.
//display the location results on the map
function showResultsLocator(results)
map = getMap();
//find results return an array of findResult.
console.dir(map); // my map object is fully working here
map.graphics.clear();
var dataForGrid = [];
//Build an array of attribute information and add each found graphic to the map
var cpt = 0;
//console.log(results);
dojo.forEach(results, function(result)
cpt++;
var graphic = result.feature;
//console.log(graphic.attributes.NAD83+","+ graphic.attributes.CIVIQUE+","+ graphic.attributes.VOIE);
dataForGrid.push([result.layerName,graphic.attributes.NAD83, graphic.attributes.CIVIQUE, graphic.attributes.VOIE]);
var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.5]));
graphic.setSymbol(symbol);
map.graphics.add(graphic); // the graphics are not added to the map. Why?
//console.log(dataForGrid);
generateTableSearch(dataForGrid);
//console.log("cpt search = "+cpt);
$('#nb_res_search').empty();
$('#nb_res_search').text('Nb. résultat(s): '+cpt);
