I have a problem with thematicwidget when I configure my xml file and I specifie my layer with fields and aliases, nameand index of layer. it works correctly for some fields, and for other it generates classes null. here is a picture that illustrates the problem and the script of my; [ATTACH=CONFIG]23795[/ATTACH] My XML file: <configuration> <layers> <layer> <url> http://localhost:6080/arcgis/rest/services/SIGMALOGITEC/BaseTest/MapServer</url> <classificationLayerName> Communes</classificationLayerName> <classificationLayerID> 2</classificationLayerID> <!-- classification methods: Descs are labels --> <classificationMethodTypeDescs>Natural Breaks,Quantile,Equal Interval</classificationMethodTypeDescs> <!-- esriClassifyEqualInterval,esriClassifyGeometricalInterval,esriClassifyNaturalBreaks,esriClassifyQuantile --> <classificationMethodTypes>esriClassifyNaturalBreaks,esriClassifyQuantile,esriClassifyEqualInterval</classificationMethodTypes> <!-- classification fields: Descs are labels --> <classificationFieldTypeDescs> Population_2004,Densite_2000,Surface</classificationFieldTypeDescs> <!-- classification fields: Types are fields --> <classificationFieldTypes> Population_2004,Densite_2000,Surface</classificationFieldTypes> <classificationBreaksMin>4</classificationBreaksMin> <classificationBreaksMax>12</classificationBreaksMax> <classificationBreaksDefault>6</classificationBreaksDefault> <dynamicLabelingPlacement>esriServerPolygonPlacementAlwaysHorizontal</dynamicLabelingPlacement> <!-- don't show labels when zoomed out beyond this scale --> <dynamicLabelingMinScale>18489298</dynamicLabelingMinScale> <dynamicLabelingFontColor>0x191919</dynamicLabelingFontColor> <dynamicLabelingFontFamily>Verdana</dynamicLabelingFontFamily> <dynamicLabelingFontWeight>bold</dynamicLabelingFontWeight> <useproxy>false</useproxy> </layer> </layers> <ui> <widget_dimensions> <width>300</width> <height>350</height> </widget_dimensions> <icons> <!-- Path to programmatically find the assets for Application Builder --> <base_url>widgets/Thematic/assets/images/</base_url> <!-- Title/label for mainState icon across the top widget panel --> <main_icon>i_thematic_icon.png</main_icon> <main_label>Main Panel</main_label> <!-- Title/label for settingsState icon across the top widget panel --> <settings_icon>i_options.png</settings_icon> <settings_label>Settings Panel</settings_label> </icons> <transparency> <comp_label>Transparency</comp_label> <defaulttransparency>0.9</defaulttransparency> </transparency> <color_ramp> <classificationFromColorRampDisplay>Lower values</classificationFromColorRampDisplay> <classificationFromColorRamp>0xCECECE</classificationFromColorRamp> <classificationToColorRampDisplay>Higher values</classificationToColorRampDisplay> <classificationToColorRamp>0x0D538A</classificationToColorRamp> </color_ramp> <classification> <methodsLabel>Classification</methodsLabel> <fieldsLabel>based on</fieldsLabel> <breaksLabel>Number of classes</breaksLabel> </classification> <dynamicLabels> <dynamicLabelsEnabledLabel>Labels</dynamicLabelsEnabledLabel> <dynamicLabelsOnLabel>Hide / Remove</dynamicLabelsOnLabel> <dynamicLabelsOffLabel>Show / Display</dynamicLabelsOffLabel> </dynamicLabels> </ui> </configuration> Need a help please 🙂
