Can we dynamically create a feature layer(or editable layer) and save it on server?, so that the user can view the data in future and edit data.
I don't know about making it editable, but you can create a feature layer from a feature collection (which you could generate from your CSV file).See the example here for some pointers.Good luck,Steve
can I save it in backend(as layer or something) for future use? so that the user need not upload each time?
I'm not sure, but I don't think this is possible within the ArcGIS Server JSAPI.You might be able to automate something using an external process, by saving the values at the end of a session, storing them somewhere, and re-loading them when the next session starts.How to actually do this is totally beyond my knowledge, but hopefully someone can help. You could also try posting the question on http://gis.stackexchange.comGood luck,Steve
If I had this requirement, I would look to creating a geoprocess to handle the input. For faster response, you could take and parse the text on the client and create a graphics layer. In the background you could send a request to a gp service and pass it the graphics. The gp service could then "copy_features" those graphics into your gdb. your gdb could already have a featureclass ready to be added to.That same featureclass could then be added to a mapservice and published to arcgiserver. that service can be loaded as a feature layer when the app starts so all previous session data will be available moving forward
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
