I have configured the search widget to search for all the As-Built drawings for a substation. However I want to create a Hyperlink within the popup Search window. Can anyone help me with this I have attached two images one for the configuartion code and one of the search widget pop up where I want the hyperlink placed. Thanks again. Cheers
Jonah,
The linkfield tag is expecting a field name that has a true URL in the attributes value. If your data does not contain this type of info I suggest using my eSearch widget which is much more robust when it come to links in the results and popups.
If you look at the documentation you will find that there is a linkfield tag that you need to add.
Search Widget Tags
I saw that but was unsucessful creating the hyperlink, do you know where any configurtaions are for the linkfield. Thanks
Robert,
Thats super helpful but I am a amateur and that looks daunting. Is there a simplified configuration code available all I really need is a hyperlink. It's just surprising that this functionality was overlooked with the out of the box widgets. Thanks for your help.
Like I said all you have to do is a field name to the linkfield tag.
<linkfield>URL</linkfield>
The requirements are that the field name URL in the example above has an attribute value in the field like
http://www.google.com or http://gis.calhouncounty.org/newsite.jpg
Yah but unfortunately the field is not a direct hyperlink but a unique identifier
Sent from my iPhone
Then your only option is to use the eSearch.
I thought you were going to say that. Thanks for your help
the eSearch is configurable using a GUI in App Builder and you can choose mots of which features you want enabled. I would say try it out before you pass it up as daunting.
