var devPlanLayer = new esri.layers.FeatureLayer(devPlanLayerURL, { mode: esri.layers.FeatureLayer.MODE_SNAPSHOT, outFields: ["*"], id: devPlanLayerID, displayOnPan: false });
dojo.connect(devPlanLayer, "onMouseMove", function (evt) { if (evt.graphic) { if (evt.graphic.attributes) { ShowMapTip(evt, evt.graphic.attributes.NAME); } } }); dojo.connect(devPlanLayer, "onMouseOut", CloseMapTip);
//function to show maptip function ShowMapTip(evtArgs, content) { CloseMapTip(); var dialog = new dijit.TooltipDialog({ id: "toolTipDialog", content: '<span style="font-size:11px; font-family:Verdana;">' + content + '</span> ', style: "position: absolute; z-index:1000;" }); dialog.startup(); dojo.style(dialog.domNode, "opacity", 0.80); dijit.placeOnScreen(dialog.domNode, { x: evtArgs.pageX, y: evtArgs.pageY }, ["BL", "BR"], { x: 5, y: 5 }); } //function to close maptip function CloseMapTip() { if (dijit.byId('toolTipDialog')) { dijit.byId('toolTipDialog').destroy(); } }
//URL used for doing query task on the features. 'DevPlanLayer' : "http://servername/arcgis/rest/services/foldername/servicename/MapServer/0",
devPlanLayerURL = responseObject.DevPlanLayer;
//URL used for doing query task on the features. 'DevPlanLayer' : "https://myserver/arcgis/rest/services/myfolder/Parks/MapServer/0",
dojo.connect(devPlanLayer, "onMouseMove", function (evt) { if (evt.graphic) { if (evt.graphic.attributes) { ShowMapTip(evt, evt.graphic.attributes.NAME); } } }); dojo.connect(devPlanLayer, "onMouseOut", CloseMapTip); var devPlanLayer = new esri.layers.FeatureLayer(devPlanLayerURL, { mode: esri.layers.FeatureLayer.MODE_SNAPSHOT, outFields: ["*"], id: devPlanLayerID, displayOnPan: false });
map.addLayer(devPlanLayer);
They way i got this to work was by adding the above code and :
dojo.require("dijit.TooltipDialog");
In the homepage.js on line 30.
The css then needs to change because the text is white.
The easiest way is to set a background color
.dijitTooltipContainer {
background-color: #2F4A24 !important;
