Hi Mark,The ASCII file must consist of header information containing a set of keywords, followed by cell values in row-major order, in order to be read by ArcGIS. As per help documentation the file format for ASCII is as follows: <NCOLS xyz> <NROWS xyz> <XLLCENTER xyz | XLLCORNER xyz> <YLLCENTER xyz | YLLCORNER xyz> <CELLSIZE xyz> {NODATA_VALUE xyz} row 1 row 2 . row n Please check and see if your ASCII files have the header information stored as mentioned above.Thank you.
