Files that help describe the problem: C:\Users\GIS_2\AppData\Local\Temp\WER6AB2.tmp.WERInternalMetadata.xml C:\Users\GIS_2\AppData\Local\Temp\WER8A90.tmp.appcompat.txt C:\Users\GIS_2\AppData\Local\Temp\WER8B5C.tmp.mdmp Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
ArcGISRuntime.SetLicense("")
ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.EngineOrDesktop) Dim supportedRuntimes() As ProductCode = New ProductCode() {ProductCode.Engine, ProductCode.Desktop} For Each c As ProductCode In supportedRuntimes If (RuntimeManager.Bind(c)) Then Return Next If (Not ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Engine)) Then If (Not ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Desktop)) Then MsgBox("ArcGIS runtime binding failed. Application will shut down.") End If End If
ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.EngineOrDesktop); ESRI.ArcGIS.RuntimeManager.BindLicense(ESRI.ArcGIS.ProductCode.EngineOrDesktop);
ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.EngineOrDesktop) ESRI.ArcGIS.RuntimeManager.BindLicense(ESRI.ArcGIS.ProductCode.EngineOrDesktop)
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
