Sorry to bring up an old topic but I have encountered an error using the .net printing method from the Developer Summit 2009.I have read through the below forum post where people do mention this issue but as I can see there is no real clear cut answer.http://forums.esri.com/Thread.asp?c=158&f=2396&t=279782My problem is when I try to go to the layout after printing the map I get an error:"Error: Unable to load .../proxy.ashx? .../MergeAndOutput.ashx status:500."I am not sure if any of the contributors of the other post can help me out with this or if anyone knows what this would relate to.The page itself does seem to be parsing my layers from viewing the source code, it just does not draw up the map - I think it is something to do with the output folder not having the correct permissions but from what I can see all users have write access to it so I am at a bit of a loss as to what the problem could be.Any help would be greatly appreciated as this is an issue that needs urgent attention!Thanks 🙂
Hi GabiNo, I couldn't get this working so we implemented the Map2PDF option instead.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
