Anyone else have saving issues? I get the error "unable to save, try again" every.single.time.
Hi Mary,
Sorry that you are having issues saving changes to your Shortlist. If you open up the deleoper tools for your browser (f12 should do the trick), do you see any errors in the console?
Mark
Hi-
I’ve been working with Patrick at ESRI on this. At first, we were seeing a permissions error but now we do not see any errors with the developer tools or with Fiddler. It really is mind boggling. AND in some cases, when I get the unable to save error and reload my map, it actually was saved… ☺
We are moving forward with replacing my shapefiles with hosted features and see if that clears anything up.
Any other ideas?
Mary Jo Watson | Senior GIS Analyst
Direct: 425.482.7728 | Main: 425.482.7600 | Fax: 425.482.7641
maryjo.watson@tetratech.com<mailto:maryjo.watson@tetratech.com>
Tetra Tech | Science
19803 North Creek Parkway | Bothell, WA 98011 | www.tetratech.com<http://www.tetratech.com>
PLEASE NOTE: This message, including any attachments, may include confidential and/or inside information. Any distribution or use of this communication by anyone other than the intended recipient is strictly prohibited and may be unlawful. If you are not the intended recipient, please notify the sender by replying to this message and then delete it from your system.
P Think Green - Not every email needs to be printed.
Unfortunately this does not sound like anything we've seen or heard of before. Would it be possible for you to share your Shortlist app URL with me to have a look?
Hoping that digging up a year-old unanswered issue isn't a bad idea, here goes:
I'm running into the same issue as described in the initial post. I saved the story map a bunch of times prior to this, and now I'm going back in to edit the descriptions with a link. Unfortunately, every time I click save, it says it's saving, I wait, and then it says "Save failed, please try again." I've tested this with Chrome Version 63.0.3239.108 (Official Build) (64-bit) and Firefox 57.0.2 (32-bit) so far with no results. Neither of the console logs provide any information relevant to the issue, unless the mixed content is the cause. The application is available here for your viewing pleasure. If this is deserving of a new post instead of reviving this one, please let me know.
