Apparently when this post was ported over to the new system the links didn't travel. Can someone update these links? I can never FIND the Data Dictionary, but I do tend to stumble across it when I am not even looking.
I would install X-Ray for ArcCatalog extension. This way you can open the XML document and view the data dictionary any time you need.
I have X-Ray. It won't give me the data dictionary under the View menu. My Local Government data model is in an Enterprise SQL SDE, rather than GDB, so I'm sure that's affecting it. But my point is, finding the Data Dictionary is like searching for the lost city of Atlantis.
Do you have the LGIM xml document? That is what you need to open, not the LGIM itself. I understand you frustration. Anyways, here is the link to the resource center for the LGIM. In one of the folders you will find the data dictionary. Here is the direct link to the data dictionary.
Steven
