What is replacing the toolbar control at V2.3 and 3.0?
What is used to generate hover over behavior.
To add my £0.02 worthI'm with ESRI on this one, basic control that anyone can create I would much prefer they invested time in better and faster mapping functionality 🙂 than basic controls you can spend 5 minutes searching on google/bing and find a tutorial & source code for.As Dominique has pointed out the code is on codeplex, so no big deal to take the code and add it to your own control library, then point your xaml to this control - very small jobCheersChris
I guess my point is more along the lines of, "Why take away something that's working just fine and so many people have already implemented"? I'm not really looking for any improvements as it seems to work just fine the way it is. Your comment on searching bing/google for tutorial & source code isn't even necessary with the current toolbar. It's there. You add it, wire it to your map and done. This all gets back to my main point, and I think Patrick's point too - Why take away something that aready exists and works just fine?
Why is any code deprecated, someone will always be using the code in question.But I am sure ESRI have good reasons 🙂Maybe one less control for them to support - although a very basic control with little that can go wrongReduce the overall download size of the toolkit assemblyEncourage more interesting and individual websites instead of many ESRI sample site clonesOnly ESRI Silverlight team can answer your question.But the effort involved to keep your App the same is very little - download the code from Codeplex and add it to your app - 30 minutes work
Well, it's true that the toolbar doesn't help that much. For example, I never really tried to add a combobox to a toolbar, but I don't think it was supported. It probably only supports command buttons.On the other hand, what would really be helpful and very tied to ESRI's map functionality is to have those buttons show up as pressed-down when the tool is active and if I pick another tool from pressing other button, the former button gets back to not-pressed state. This would require closer handling of what Draw object is currently active in the map. It would work even if I have different toolbars.Wish list? Or does anyone know of something close to it?
...But the effort involved to keep your App the same is very little - download the code from Codeplex and add it to your app - 30 minutes work
