//inside of a switch statement looking at the layer name returned case 'Subdivision': tcell.innerHTML = "<span style='font-weight:bold'>Subdivision History (Name and Number, sorted most recent to oldest):</span>"; tcell.innerHTML += "<br> <span style='font-style:italic'>For reference only - not to be relied upon as a legal search of the property.</span><br>"; //need to loop thru all of the idResults that are sub history //date, name, docname, annsubid var featcount = 0; while (idResults.layerName == 'Subdivision') { featval = idResults.feature.attributes['SUBDATE']; sortlist[featcount] = new Array(2); sortlist[featcount][0] = new Date(featval).valueOf(); //get date in ms for sorting sortlist[featcount][1] = "<a href='http://myserver/" + idResults.feature.attributes['LINK'] + "' target='_blank'>" + idResults.feature.attributes['NAME'] + " (" + idResults.feature.attributes['ID'] + ")</a><br>"; featcount += 1; } //sort descending sortlist.sort(numbersort); for (var z = 0, iz = featcount; z < iz; z++) { tcell.innerHTML += sortlist[1]; } break; //after the switch statement...add the cell to a table row and add that to the table above an existing row trow.appendChild(tcell); dojo.byId('tblbody').insertBefore(trow,dojo.byId('rowSummary')); // here's the basic function I used to sort numbers. note it's taking in arrays function numbersort(a, b) { //sort the 1st element in 2 arrays descending //used to sort subs, agreements, PUD docs, etc... return b[0] - a[0]; }
sortlist = []; for (var i = 0, il = results.length; i < il; i++) { result = results; attribs = result.feature.attributes; sortlist = new Array(2); sortlist[0] = attribs.PIN; //which ever field you want to sort on sortlist[1] = attribs; } sortlist.sort(numbersort); //now run your existing for loop but at the top reset attribs = sortlist[1] for (var i = 0, il = results.length; i < il; i++) { attribs = sortlist[1]; if (attribs.Active === "N") { s.push("<tr style=\"background-color:#F28282;\"><td nowrap><font size=2.5> " + attribs.Full_Address + "</font></td><td nowrap><font size=2.5>" + attribs.GIS_Key + "</font></td><td nowrap><font size=2.5>" + attribs.PIN + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_Name + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_Address + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_City + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_State + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_ZIP + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_Date + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_Update + "</font></td><td nowrap><font size=2.5>" + attribs.Occupant_Name + "</font></td><td nowrap><font size=2.5>" + attribs.Occ_Phone1 + "</font></td><td nowrap><font size=2.5>" + attribs.Occ_Phone2 + "</font></td><td nowrap><font size=2.5>" + attribs.Village + "</font></td><td nowrap><font size=2.5>" + attribs.Active + "</font></td></tr>"); } else if (attribs.Village === "N") { s.push("<tr style=\"background-color:#BDBDBD;\"><td nowrap><font size=2.5> " + attribs.Full_Address + "</font></td><td nowrap><font size=2.5>" + attribs.GIS_Key + "</font></td><td nowrap><font size=2.5>" + attribs.PIN + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_Name + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_Address + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_City + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_State + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_ZIP + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_Date + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_Update + "</font></td><td nowrap><font size=2.5>" + attribs.Occupant_Name + "</font></td><td nowrap><font size=2.5>" + attribs.Occ_Phone1 + "</font></td><td nowrap><font size=2.5>" + attribs.Occ_Phone2 + "</font></td><td nowrap><font size=2.5>" + attribs.Village + "</font></td><td nowrap><font size=2.5>" + attribs.Active + "</font></td></tr>"); } else { s.push("<tr><td nowrap><font size=2.5> " + attribs.Full_Address + "</font></td><td nowrap><font size=2.5>" + attribs.GIS_Key + "</font></td><td nowrap><font size=2.5>" + attribs.PIN + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_Name + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_Address + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_City + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_State + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_ZIP + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_Date + "</font></td><td nowrap><font size=2.5>" + attribs.Owner_Update + "</font></td><td nowrap><font size=2.5>" + attribs.Occupant_Name + "</font></td><td nowrap><font size=2.5>" + attribs.Occ_Phone1 + "</font></td><td nowrap><font size=2.5>" + attribs.Occ_Phone2 + "</font></td><td nowrap><font size=2.5>" + attribs.Village + "</font></td><td nowrap><font size=2.5>" + attribs.Active + "</font></td></tr>"); } }
//make new row & cell to add layer info to trow = document.createElement('tr'); tcell = document.createElement('td'); //apply alternating style to the row - rowodd and roweven are classes in a CSS file with different background colors so the table has alternating row colors //NOTE - IE has issues w/ setting class have to work around by using non-standard className //see http://webbugtrack.blogspot.com/2007/08/bug-242-setattribute-doesnt-always-work.html if (rowcount % 2 == 0) { if (dojo.isIE) {trow.setAttribute("className","rowodd"); } else { trow.setAttribute("class", "rowodd"); } } else { if (dojo.isIE) { trow.setAttribute("className", "roweven"); } else { trow.setAttribute("class", "roweven"); } } //use data from the featureset attributes to fill the innerHTML of the tcell here..... //tcell.innerHTML = "name: " + attribs[NAME] ; trow.appendChild(tcell); //now append that row to a tablebody - in this case one that already exists.. dojo.byId('tblbody').appendChild(trow); //example of inserting above the existing bottom row instead of appending.. //dojo.byId('tblbody').insertBefore(trow,dojo.byId('rowBtmRow')); //increment rowstyle counter rowcount += 1;
