When I used your latest identify widget, I noticed that the default identify is still active. Do you know the way to disable the default identify from the index.mxml until the bug fix is released?
value = obj[cArr[1]] ? String(obj[cArr[1]]) : "";
value = obj[cArr[0]] ? String(obj[cArr[0]]) : "";
The name attribute is the EXACT ALIAS (as it is displayed in the REST services directory) of the field and is aREQUIRED attribute. The alias attribute is optional as this information can automatically be retrievedfrom the map service. If you want to specify an alias that is different than the alias specified in ArcMapthan you can set this value.
Richard,So you are saying that you can get the GCOD when using the identify widget on a polyline Using Version 3.1 of the Identify Widget?
Richard,OK, that makes me feel better... The API team is aware that there is still an issue with Polylines and it will be addressed in the next version of the API.
