As far as I can tell, the aboce code calculates the weighted center. There is no guarantee that this is inside the polygon. For instance try it on a polygon shaped like a "C", or a ring with a hole in the center.
there are probably half a dozen reasons not to do it this way that Morten and Co. can point out, but doing it client-side using the extension method below works for me.
<Extension()> _ Public Function GetTruePolygonCenter(ByVal pgnPolygon As Polygon) As MapPoint Try Dim iNumberOfMapPoints As Integer = 0 Dim centroidX As Double = 0 Dim centroidY As Double = 0 For Each pc As PointCollection In pgnPolygon.Rings For Each mp As MapPoint In pc centroidX += mp.X centroidY += mp.Y iNumberOfMapPoints += 1 Next Next Return New MapPoint(centroidX / iNumberOfMapPoints, centroidY / iNumberOfMapPoints, pgnPolygon.SpatialReference) Catch ex As Exception Return Nothing End Try End Function
