Hy,could you please provide the Arcgis server logs in "verbose mode".See here: http://bitbucket.schuller.lu/pchprintsoe/wiki/ErrorReportingYou can also mail them to "tom@schuller.lu"Tom
Hi TomI am having an issue with using the latest SOE/Widget with Flex 3. It installs fine and I can see it has upgraded the SOE as I have the added capbability option (10.1) however when I go to use the widget in a Flex 3 application it opens up as expected however there is no Red Extent indicator as there was previously - also if you hit print nothing happens. I have reverted back to the previous SOE and widget, which works for V2.5 applications, but not 3.0 applications. Would you be able to help me trouble shoot? I have tested this on both my Dev and Test boxes with the same result. I have attatched my verbose logs and the debug message from the widget. Your assistance is greatly appreciated. Thanks very muchKind regards,Dominique
Hello Dominique/TomI am experiencing the same issue on my 3.0 viewer when I add this printpch widget. I am able to register the java binary but there is no print area being displayed and nothing on the print click. Please advise..Thanks!!!-pAWAN
Some news concerning the PchPrintSOE and it's widget:PchPrintSOE (http://bitbucket.schuller.lu/pchprintsoe)autoregistration:Copy the "jar" file into "<AGS-Server-Home>\java\lib\ext"Open a command prompt in the same directoryFor registration, execute "..\..\jre\bin\java -jar PCHarcgisSOE.jar server domain user password register"For un-registration, execute "..\..\jre\bin\java -jar PCHarcgisSOE.jar server domain user password unregister"PrintGUI, to debug easier the printing codeOpen a command prompt in the same directory as aboveExecute "..\..\jre\bin\java -jar PCHarcgisSOE.jar printgui"Just copy/paste from the widget the "webmapobject" or the resturl to test your printingcan act as GP-geoprocessing tool (more infos will soon be available)full ArcGIS Server 10.1 support�??PchPrintWidget�??multiple templates exposed by mxd/mapservicescustom bitbucket projects for FlexViewer25 and FlexViewer30PchPrintWidget for FlexViewer2.5 (http://bitbucket.schuller.lu/pchprintwidget)PchPrintWidget for FlexViewer3.0 (http://bitbucket.schuller.lu/pchprintwidget30)Let me know about your experience and feature request by the BitBucket issue system.Tom
Přihlášení členové mohou přispívat, sledovat novinky a další. Jste tu noví? Zaregistrujte si účet zdarma.
