I am trying to Calculate Solar Radiation | ArcGIS for Local Government to my 3D Geometry Dan Patterson Hisham Alghamdi Jayanta Poddar#calculate Solar Radiation
I would work in a new folder environment. The path to your data contains punctuation etc.
Is this a package? are you working in ArcMap or ArcGIS Pro?
We cant see your inputs
Dan, Thanks for your quick response, I changed my database path environment to new folder, and again I run the “Visualize Solar Radiation on Building Roofs” tool but no luck again facing the same error. Please find the error messages as attachments.
Here I would like to bring to your notice that when I run the An ArcGIS Pro project package used to calculate solar radiation maps (Calculate Solar Radiation configuration file) by default it is installing and executing from the default users arc gis path (C:\Users\xyz\Documents\ArcGIS\Projects).
The data type is “File Geodatabase Feature Class” 3d Buildings and I am working in ArcGIS Pro.
Requesting you to please review and suggest me in this regard.
Thanks in advance!
Look at the line in the error.... Can't find....
That is the path type I was referring to. I don't understand why it is full of punctuation and so long.
In short … it can't find the raster, and I suspect you will have to resolve the installation and/or confirm the rasters
Did the path correct the issue?
No, it was not worked. BTW Congratulations for achieving the “2017 Top Contributors Geonet Award”
Thanks Vamsi...
Did you install the supplemental python package? Install add-in - Calculate Solar Radiation | ArcGIS Solutions for Local Government
And I assume you have a standard or advanced license for ArcMap (hence Pro) and ….(To deploy Calculate Solar Radiation with the ArcGIS Solutions Deployment Tool requires specific software.)
Hi Vamsi,
Could you try and install the package to a different location please? For example c:\temp\solar. You can use the Extract Package GP tool to extract it to a custom location. make sure not to use the cache option.
Let me know if this works.
Gert
