import arcpy import glob, os import time from time import localtime from time import strftime import datetime tic = time.clock() #*********** PRINCIPALES VARIABLES ************* arcpy.env.overwriteOutput = True prefijo = "PruebaPronostico.SDE." variable = "pslv" inNetCDF = "C:\Datos_IIE\pruebasmosaico\SalidasNETCDF/DOMAIN1_2013070318.nc" outLoc = "Database Connections/Con_PruebaPronostico.sde/" outLoc2 = "C:\Datos_IIE\pruebasmosaico/raster/" # Process: Create Mosaic Dataset arcpy.CreateMosaicDataset_management(outLoc, variable, "PROJCS['Lambert_Conformal_Conic',GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Lambert_Conformal_Conic'],PARAMETER['False_Easting',0.0],PARAMETER['False_Northing',-27.0],PARAMETER['Central_Meridian',-124.17],PARAMETER['Standard_Parallel_1',0.0],PARAMETER['Standard_Parallel_2',0.0],PARAMETER['Scale_Factor',1.0],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Kilometer',1000.0]];-20037.7 -30225.3 149134210447.956;1 1;1 1;0.000001;2;2;IsHighPrecision", "", "") nc_FP = arcpy.NetCDFFileProperties(inNetCDF) nc_Dim = nc_FP.getDimensions() #rr = outLoc2 + '*' #r = glob.glob(rr) #for e in r: # os.remove(e) test = outLoc + '*' r = glob.glob(test) list = [] for i in r: os.remove(i) for dimension in nc_Dim: top = nc_FP.getDimensionSize(dimension) for i in [0, 6, 12, 18, 24, 30, 36, 42, 48, 54, 60, 66, 72, 78, 84, 90, 96, 102, 108, 114, 120]: if dimension == "time": dimension_values = nc_FP.getDimensionValue(dimension, i) daat = "time '"+str(dimension_values)+ "'" print dimension_values nowFile = str(i) testt = dimension_values.replace("/","").replace(":","").replace(".","").replace("'","").replace(' ','') rast = name6 + name5 + name4 + "_" + name7 list.append(dimension_values) rastt = "time" + nowFile print rast # Convierte todos los tiempos del NETCDF A LAYER arcpy.MakeNetCDFRasterLayer_md(inNetCDF, variable, "lon", "lat", testt, "", daat, "BY_VALUE") # CONVIERTE LAS LAYER A RASTER Y LOS GUARDA EN EL DIRECTORIO INDICADO arcpy.CopyRaster_management(testt, outLoc2 + rastt, "", "", "-3,402823e+038", "NONE", "NONE", "", "NONE", "NONE") #arcpy.MakeRasterLayer_management(outLoc2 + rastt, "rastt", "#", "feature.shp", "1") arcpy.MakeRasterLayer_management(outLoc2 + rastt, rastt, "", "0 706.764 5373 4729.764", "") # APLICAR SIMBOLOGÍA arcpy.ApplySymbologyFromLayer_management (rastt, "C:\Datos_IIE\pruebasmosaico\sombologia.lyr") # Process: Add Rasters To Mosaic Dataset arcpy.AddRastersToMosaicDataset_management(outLoc + variable, "Raster Dataset", rastt, "UPDATE_CELL_SIZES", "NO_BOUNDARY", "NO_OVERVIEWS", "", "0", "1500", "", "", "SUBFOLDERS", "ALLOW_DUPLICATES", "true", "true", "NO_THUMBNAILS", "") #Assign colormap using clr file ###arcpy.AddColormap_management(outLoc2 + rast, "#", "C:/Datos_IIE/pruebasmosaico/test3.clr") # Process: Add Field arcpy.AddField_management(outLoc + variable, "tiempo", "DATE", "", "", "", "T", "NULLABLE", "NON_REQUIRED", "") # Process: Calcular stadisticas arcpy.BatchCalculateStatistics_management(outLoc + variable) # Agregamos el tiempo a los raster dentro del mosaico mm = len(list) for j in range(1, mm): #******************************Funciona para una celda ********** with arcpy.da.UpdateCursor(outLoc + variable, ["tiempo", "OBJECTID"]) as cursor: for row in cursor: index = int(row[1]) print index row[0] = time.strftime(str(list[index-1])) cursor.updateRow(row) #******************************************************************* toc = time.clock() print toc - tic
