I've recently upgraded to the latest SDK and started using the LocationViewShed.
That was when I started getting the following warnings repeatedly:
D3D11 WARNING: ID3D11DeviceContext::OMSetRenderTargets: Resource being set to OM RenderTarget slot 0 is still bound on input! [ STATE_SETTING WARNING #9: DEVICE_OMSETRENDERTARGETS_HAZARD]
D3D11 WARNING: ID3D11DeviceContext::OMSetRenderTargets[AndUnorderedAccessViews]: Forcing PS shader resource slot 1 to NULL. [ STATE_SETTING WARNING #7: DEVICE_PSSETSHADERRESOURCES_HAZARD]
I've disabled everything else and left only the very straight forward creation of the LocationViewShed but the warnings remain. If I disable the LocationViewShed creation - they are gone.
Besides the warnings, it seems to be working fine.
This is the creation code (The actual values are in comments):
if (nullptr == m_locationViewshed) {
m_locationViewshed = new LocationViewshed(m_stSystemPosition.location,
static_cast<double>(m_stSystemPosition.fAzimuth), //0.0
static_cast<double>(m_stSystemPosition.fElevation) + 90, //85.0
static_cast<double>(m_stSystemPosition.fFovDeg), //30.0
SYSTEM_VERTICAL_FOV_DEG, //45
0,
SYSTEM_RANGE_2_METERS, //1400
this);
m_locationViewshed->setVisible(true);
m_analysisOverlay->analyses()->append(m_locationViewshed);
LocationViewshed::setVisibleColor("green");
LocationViewshed::setObstructedColor("transparent");
Any ides what causes the warnings and how to get rid of them?
Thanks!
