Hi,Can you post your code? - most folk on the forum here will have the sample data so we should be able to able to help you out pretty easily I hope.CheersMike
Mike,...Many thanks for any assistance you can provide.Phil.
Hi Phil,your TPKs probably have a different projection/Spatial Reference. Whenever the first layer is loaded the Map's projection will be set. You have to explicitly change it after that. I'm pretty sure if you use TPKs with the same projection, it will work.for example, look at the "tiled" layers here.http://viewer.nationalmap.gov/example/services.htmlhttp://basemap.nationalmap.gov/ArcGIS/rest/services/USGSTopo/MapServer has projection / WKID of Spatial Reference: 102100 (3857)http://gis1.usgs.gov/arcgis/rest/services/gap/PADUS_Owner/MapServerhas projection Spatial Reference: 102113 and will not be able to be viewed on the same map at the same time.
Přihlášení členové mohou přispívat, sledovat novinky a dělat další věci. Jste tu noví? Zaregistrujte si bezplatný účet.
